Best Plasma for Sky - mainly sports
Discussion in 'Plasma TVs Forum' started by irmster, Aug 4, 2004.
  1. irmster
    irmster
    Am finally going to take the plunge and invest my hard earned reduncancy money in a 42" screen. Will mainly be used for connection to Sky + for sports/football, but also to a Pioneer DVL 919 Laserdisc (remember those) DVD combi player.
    I have read the various threads about the screen problems when watching Skysports etc, but there does not seems to be a definitive solution.
    Any assistance on screen choice will be appreciated :lease:
    Budget is quite flexible (ish!)
  2. Piers
    Piers
    Dec 11, 2002
    1,994
    Cheshire
    +230
    Panasonic 42PW6 with J S Technology RGB to VGA converter will give you as good a Sky picture as you can get. Run it in for the 1st 200 hours with reduced contrast and brightness then have it professionally calibrated.
    Piers
    Home Cinema Engineering
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    A scaler would help, and a Pioneer or panasonic Hi def screen is worth considering too. The dream setup for me is probably the panasonic hi def, and a scaler, ask me what make after Thursday, when Mr Lumagen is going to convince me his products are the best.
  4. irmster
    irmster
    so the Panasonic not the Pioneer. What sort of price would the scaler be?
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    About £1k. Pio/panny choice is personal, there will be plenty of people who'd say the opposite, and I have no issue with that. The model would be the 43mx-1
  6. Wazy
    Wazy
    You say that your budget is flexible...
    You could go for Piers suggestion at just a touch over £2000, or go with a HD screen and scaler for £4000-5000.
    The best thing to do really is arrange to demo both options for yourself and see if you think its worth spending more on scaling and Higher Definition. I personally didnt and am more than happy with my Panny PW6 :)
    The trouble with sky digital is that the image is compressed, but luckily sky do allocate a higher bitrate to sky sports, so football matches look the best they can. Until HDTV takes off it will never be perfect, but viewing using a JS Tech RGB2VGA box its very acceptable indeed, and preferable over a direct scart connection which can appear softer.
