best place to get a psp with less than v2.0 firmware?
Discussion in 'Playstation Forums' started by Lighty, Oct 25, 2005.
  1. Lighty
    Lighty
    Mar 7, 2002
    3,217
    East Yorks
    +230
    just reading about the emu's etc
    and i fancy a little look at this!
    how do i go about sourcing one with less than 2.0 firmware - are all the ones in the shops going to be newer than this?
    cheers
    lighty
  2. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    No, the ones in the shop will definately not be newer than 2.0
    2.0 is fine anyway since you can downgrade to 1.5 from 2.0, so it doesn't have to be one that is "lower" - just one that is no higher.
    Pretty sure all the ones in the shop will still be 1.52 - irrelevent anyway given the above
  3. Lighty
    Lighty
    Mar 7, 2002
    3,217
    East Yorks
    +230
    are the white ones going to be ok too?
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,670
    +6,626
    My bro went to HK, bought from shop + got a original 1.5! (3 weeks ago)
  5. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    That was just luck!
    Anyways, as long as the one in the shop has 1.51, 1.52 or 2.0, you can downgrade to 1.5. Ask to check beforehand.
  6. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    Just to reiterate...
    NO PSP IN THE WORLD SOLD COMMERCIALLY IN ANY RETAIL OUTLET RIGHT NOW IS SELLING ANY PSP WITH A FIRMWARE NEWER THAN 2.0
    Who knows they may start turning up very soon.
    Reason being is that there is simply no way that the recent upgrades will make it into the psp's being made and into the shops in such short time. Its impossible.
    Heck I bought a motherboard recently and it came with the original bios from when it was first released (as do most).
    Going off topic there - just ask before you buy, that should alleviate any unwarranted paranoia. :hiya:
  7. Lighty
    Lighty
    Mar 7, 2002
    3,217
    East Yorks
    +230
    thanks for that
    i've been doing a bit of research but can you tell me apart from hooking up to a pc can the firmware be updated any other way?
    just asking in case i put a film / game in it and it does the upgrade on its own !!
    may be a really dumb question .....
  8. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    Yep its a really dumb question...
    only kidding ;)
    Nah right just to make sure you don't worry.
    NO GAME WILL UPDATE THE FIRMWARE WITHOUT ASKING
    It will say "You have to upgrade your firmware to play this game, do you want to do this now?" And you'll have a yes\no screen. If you say yes then you will have to then agree to a license agreement, then go through a few more screens. Abit like installing a computer game\program.
    YOU MUST ALSO HAVE THE POWER CORD PLUGGED IN THE PSP WHEN UPGRADING THE FIRMWARE.
    So there is more chance of Elvis knocking on your door for a cup of tea and a chat than anything going pear shaped.
    The normal way to upgrade your firmware (the only way) with the MPH downgrader is by following the instructions that come with it.
    Its all done from the memory card - no cable should be connected to your pc!!! (obviously you connect the USB cable to the PSP to put the files on the memory card)
  9. GreenBhoy
    GreenBhoy
    Jul 30, 2003
    439
    Swindon
    +10
    Aint so - Just got my flashy new White PSP from Yesasia (no customs fees) - but F/W 2.01 :thumbsdow
