Best Place To Get a Custom PC Built ?
palace1000
I have looked at a couple of places like Mesh, Evesham, PC Specialists.
However I am not sure who are considered reliable, etc.
I am looking at the following,
Intel Core 2 Duo E6300 Dual Core Processor
XP Media Centre
1024 MB Ram 800 MHZ
250GB HD
DVD Writer
Ge Force 7600GS - or similar
Price from Mesh was 612.88 but the RAM was only 533Mhz, however really wanted 800Mhz.
I would appreciate any advice as where people consider it best to buy from.
Razor
I have used Mesh in the past and I have built my own systems. Mesh do make good pc's and their customer service is also good. Can you not ask Mesh to change the memory to 800Mhz? I am sure they will oblige if you ask.
You can use suppliers like CCL who will build your pc to your exact spec.
http://www.cclonline.com/product-categories.asp?category_id=81
I believe Scan also do a similar service. Scan are slightly cheaper than CCL.
Which ever route you choose I wish you luck. :thumbsup:
