Best place to find 2nd hand projectors ?
Discussion in 'Projectors, Screens & Video Processors' started by samwiley, Nov 26, 2001.
  1. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    I may be looking to use an LCD projector as part of a theatrical production, so high(ish) lumens is important, therefore I'm probably looking at business rather than home use projectors.
    Does anyone know a good place to start looking for good deals second hand?
    Cheers!
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Any idea of screen size?
    Throw?
    Front / Rear?
  3. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    Rear probably.
    Not sure about throw/size at the moment, I just want to see what is available for the money. (Cost maybe prohibitive eg. £10k is too much).
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Sam,
    Summary - You need a bright projector, with either a very wide angle zoom lens as standard or the option to change to a wide angle lens, oh and it has to be cheap (s/h) but not knackered (ie requires new lamp & servicing). Is that about right?
    Hmm... Think you might be searching a long time for something that fits the bill. Have you considered hiring?
    Most major cities in the UK have AV equipment hire companies. They stock exactly what you need, and can work out hire rates for short or long term projects. Want some phone numbers?
    Regards
  5. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    Chris
    Thanks for the suggestion, I think renting is probably the way to go.
    Got any numbers in London?
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Classic Video Services - 020 7224 3342
    Saville AV - 01252 540721
    Blitz - 0870 162 1000
    Edric - 0800 980 2853
    If these companies can't help, ask them for the names of other AV hire companies.
    Regards
