Best place to buy modded XBox
Discussion in 'Xbox Forums' started by klnc, Jun 25, 2003.
  1. klnc
    klnc
    Oct 2, 2002
    385
    London
    +36
    Says it all really.... Been looking at Premodded.co.uk... Quote £170. Do people have any experience of this outfit or have any other recommendations.
    On a similiar vein, apart from having the possibility of having multiple BIOS and the external printer port access, is there any difference between the X-Ecuter Lite and Pro. And are there any probs with putting a larger hard disk in the unit - eg over heating etc... Do people go for the biggest available?
    Apologies if this is a stoopid question - first time I;ve ventured out of the AV type forums, so grateful for any help
    Ta.
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    If you buy a normal Xbox you can get it modded by Saurian, who is based in Kilburn. You can find him on the forums at www.ntsc-uk.com. Alternatively, Yod@ at the rllmuk.com forums is supposed to be very good - check out the trading folder on there.
    Both these guys should be able to advise you with the other questions you had.
  3. Jason S
    Jason S
    I've used modconsole.co.uk in the past, as have a few friends and they seem to be happy with the service.
    £170 seems reasonable considering the cost of an X-Box, mod chip and the hassle of fitting it then setting it up. Easy once you've done a few, but potentially :suicide:
    Difference between the chips is essentially multi bios, I've not seen the need for it myself, but you may wish to switch between the linux bios & the xbox bios (executer etc), different versions etc
    Hard Drives - I've a 120Gb Maxtor (£91) drive in mine and heat is not a problem. Get the biggest you can afford, as you'll easily fill it up, especially if you opt for the emulators, and you'll only regret it if you don't.
  4. De|ta
    De|ta
    the xbox can only address 137gb of HD space. So if you buy a 160GB, u can only use upto 137gb of it. Dont buy anythhing bigger, theres really no point.
    X2 lite or pro. Basically, if you have to ask - u want the lite. Get the lite
    i buy all my chips from here:
    http://www.baldbouncer.co.uk/xbox.htm
    he does premods as well, sound as a pound :)
  5. Ono
    Ono
    Oct 18, 2000
    1,580
    London
    +177
    premodded are fine.
    Trustworthy and great service.
  6. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    I have used goldberg-mods.com or.co.uk
    very good very helful and fast process
  7. holtehero
    holtehero
    Sep 10, 2002
    2,820
    Cambridge
    +1,741
    Premodded are excellent, bought a special editition xbox with 40gb hard drive, arrived two days later
    If you ask he will even put arcade emulators on the hard disk for free
  8. klnc
    klnc
    Oct 2, 2002
    385
    London
    +36
    thanks for the responses guys... premodded's website seems to have been down for the last few days.
    Think will get one on the highstreet to get to grips with it first (can always take it back if i don't like it) and get a decent games bundle, then get it modded in due course. Been some time since I owned a games console, so need to ease myself back into it gently i think!
  9. Paden
    Paden
    Jul 27, 2000
    572
    +19
    Once you've had your box moded, do you still require a dongle to play DVD's.
    Is there such a thing as a multiregion dongle?
    Cheers, Paul
  10. peasoup
    peasoup
    Nov 19, 2002
    52
    no u dont need a dongle...itll play any region
  11. Paden
    Paden
    Jul 27, 2000
    572
    +19
    & do you navigate via the contoller rather than a remote?
    Cheers, Paul
  12. Dean
    Dean
    Jun 20, 2003
    2,887
    London
    +263
