Best place to buy HS2? - Cheapest?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sparkybun, May 19, 2003.
  1. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    Can anyone recommend the best/cheapest place for a HS2. I've so far had www.digital-point.co.uk recommended.
    Ta,
    Mel
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Try pricerunner for the cheapest!
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,662
    Newcastle
    +103
    If you mean the Sony HS2 LCD projector you would be better putting this in the LCD section of the forum. If not then ignor this :)
  5. DEANO65
    DEANO65
    Feb 19, 2003
    45
    leeds
    empire direct 650
  6. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Mel, I've searched and you've already found the cheapest place for a multiregion HS2 (digital-point @ £599). RGB Direct have it for £594.97 inc. delivery for region 2. Probably worth the extra £5 for region free though. :)
    Have you thought about hanging on a month and seeing what the Toshiba RD-XS30 is like? It's cheaper (£525) than the HS2 and has a larger HD (60GB). I know I will.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Yes waiting for the Toshiba may be a good idea (only 11 days!). The only thing the Panasonic HS2 has which the Toshiba doesn't is the JPEG viewer. Some people love this and some (like me) are yet to use it (although I may get a digital camera soon). The Toshiba has a 60GB HDD though (compared to the 40GB of the HS2). Thus the Toshiba might be a good purchase.
  8. Hambone
    Hambone
    Jul 9, 2002
    98
    11
    Edinburgh
    +6
    I don't think the jepg viewer on the HS2 is a big selling point as most Digital Cameras can plug straight into the tv,or bung them on a cd-r and stick it in the DVD.Most software that comes with your burner will do it ,nero does.
    I was going to buy the HS2 a few months ago but am holding out for a multi-region tosh.
  9. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    I'm not sure how correct this is but www.kingdom88.com/futuretronic are advertising a DMRHS2 for £499!!
    I've e:mailed them and I'm awaiting a reply!
    Will keep you informed
    Mel
  10. DaveP
    DaveP
    You never know your luck! Most of their other prices seem expensive in comparison to some other sites, interesting they are still advertising the e20 at £799!
    DaveP
  11. Furber
    Furber
    I don't believe futuretronic exist anymore. I reported this to Pricerunner where I found the link & they have investigated & agree & have taken them off their listings.
  12. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    hi,
    Yes, they do apparently exist but difficult to get hold of. I eventually did speak to someone on the phone that explained that they sold out of the HS2 in April. However, after the conversation I would certainly not be purchasing anything from them over the net or by Mail order. They seemed a little vague to say the least.
    cheers
    Mel
  13. ebbone
    ebbone
    "I don't think the jepg viewer on the HS2 is a big selling point as most Digital Cameras can plug straight into the tv..."
    If this is correct, then can the photos be copied onto a HDD. If so which machines?
  14. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Richer Sounds are selling MR HS2s for £499.
