Best place to buy component cables?
rhinoman
http://www.vdctrading.com/
Order on line but they phone you back for your CC no, same cables as Media Factory but cheaper because you buy direct.
petrolhead
Hey John just noticed, you and I have exactly the same number of posts. Does that make us brothers :rolleyes:
Exactly what spec did you buy with which connectors?
G
graham.myers
Do VDC make them up to spec. When I looked I got the impression you got the cables "flat packed" and home assembly was required.
petrolhead
Single cables pic
rhinoman
I got the made up single cables form Media Factory although I've used VDC since direct after the cables from the Media Factory appeared to be delivered direct from VDC but with Media Factory prices:(
Cant fault the cables or the service, very quick and if you require tech siupport they seem to know what they are talking about. Do you really need branded cables for more money like Ixxos or QED....these do the job and leave more money for dvd's;)
