Best place to buy a Hoya Filter for the AE100?
Discussion in 'Projectors, Screens & Video Processors' started by bunkerbuster2, Jul 15, 2003.
  1. bunkerbuster2
    bunkerbuster2
    As subject... I've just got my neew AE100 and want to see what it's like with the Hoya Filter
    Can anyone tell me the best place to get one on the high st ?
    (also which dimeter do I need to screw directly into the AE100 lense)
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Try Jessops. Although every time I go, they never have any in :(
  3. mince bigalow
    mince bigalow
    i got one from jessops a couple of days ago, the only sizes they had were 49mm and 58mm so i went for the bigger one
    as far as i know no hoya filters will screw in, i taped mine on round the edge, its not a bad fit
  4. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    sorry to sound daft, but what exactly does the filter do for the picture????
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Hi and welcome to the forums.
    Check the FAQ - sticky at the top of the page - link there to a thread about the Hoya filter, as well as lots of other projector info goodness.
    Sean G.
