Best picture
Ico.
What is best way to get the best picture on the 360? Hdmi cable really improve it much?
Depends on what cable you are currently using... if you are using the composite cable that the 360 comes with then that isn't a HD lead lead so it would massively improve that... if you are using a VGA or Component lead not so much.
m1ket
If you have hdmi on your tv go with that
There is very little difference between hdmi cables on less than 2m cables i use a £10 cable from argos
Make sure once you have plugged it in you go to setting > display and select the correct 720p or 1080p setting :thumbsup:
Dinky Dragon
I get my cables from these guys - Amazon.co.uk: Neet Cables - Electronics & Photo
Awesome quality and brilliant price. Dont go spending all your wages on an expensive cable, its a digital signal of 0s and 1s. What youre wanting to pay for is build quality not a big name or the mumbo they preach to you in shops. ;)
kobe74
you can get hdmi cables from poundland for £1, it works just a well as the official xbox cable which cost about £20
sdb123
There is no 'best'.
What looks better to you is all that matters and that will purely be down to how your display processes HD sources through each connection (Component, VGA or HDMI). Personally I use VGA for gaming on both my Plasma and Projector.
