Best Picture Settings to reduce solarisation...
Discussion in 'Plasma TVs Forum' started by NIIK_TT, Jan 16, 2003.
  1. NIIK_TT
    NIIK_TT
    I have a budget Daewoo Plasma. Sometimes the picture suffers from bad solarisation depending on the broadcast.
    I have connected up a Video Tuner to the Video input of the plasma and the picture is OK. I then connected up the Pro V Progressive scanner via the the VGA input of the Plasma and I think the picture is not quite as good.
    I have been adjusting the picture settings on both the Pro V and the Plasma and seem to be constantly changing them depending on broadcast clarity.
    Should I only adjust the Pro V settings or just the plasma or both.
    If so what should I adjust to improve picture. The TV broadcast is from a standard RF.
    thanks
