Best Picture/Recording Quality
Discussion in 'Blu-ray & DVD Players & Recorders' started by stanleyntl, Jun 27, 2004.
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Of Panasonic, Sony, Philips, Pioneer and JVC which produces best picture quality from a) internal TV tuner b) external video source (S-VHS deck or SKY box)? :lease:
    Of these which serves equally well for playing back commercial DVDs? Do any compare well with dedicated DVD players?
    Regards,
    Darren
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    As in the DVD player market Toshiba (who are not on your list) are ahead by a long way. IMHO the playback of the Toshiba DR1 is comparible almost to a similarly priced Toshiba DVD player.
    The JVC and Panasonic range are next up if you have a progressive scan capable monitor/TV (or plan to get one). If not then the Sony is the best with Pioneer second and the others more-or-less equal thereafter.
    JVC seems to currently lead on this front. Although internal TV tuners are NEVER high quality!
    The Philips would be a bad option for recording from VHS/SVHS as it has no hardware Time Base Corrector (all the others do in one form or another). Other than that they will all create good quality copies from Sky - although again the Philips is at an disadvantage as it has limited recording modes (all the others have Flexible Record or dozens of settings allowing you to maximise quality).
