Best picture from Z1?
Discussion in 'Projectors, Screens & Video Processors' started by uksteve69, Aug 27, 2003.
  1. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    I have my Sanyo Z1 connected by component leads which is being fed progressive scan from my harman kardon DVD player. I have also connected my Z1 using the vga socket to a scart on the DVD player.
    When I switch between the 2 connections the picture from the scart - vga connection seems sharper, not as soft as the progressive scan connection. My question is, should this be the case? I thought that progressive scan gave the best picture?
  2. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
    Perhaps you should try a comparison between progressive and interlaced through your component out's first, this should determine if your deinterlacing in the HK is causing the softening.
    On some of the cheaper PAL PS players quite a few people have posted that the progressive picture was softer than interlace.
  3. Underscore
    Underscore
    Note also that RGB is theoretically a better interface than YCrCb (or YPrPb for progressive) since there is more effective bandwidth available for the luma signal, to which the human eye is more sensitive than chroma.
    So, the simple answer is to go to HTPC so you get progressive plus RGB and a better scaler than the Z1 has as well...
    _
  4. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    Thanks for the feedback.
    The missus is gonna kill me, I've only just bought the h/k DVD player!!.
    Guess I'm gonna have to give the HCPC a go then.
