Best Pic Quality....
Discussion in 'Projectors, Screens & Video Processors' started by Gliese 581c, Aug 7, 2004.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,759
    On AVForums
    +569
    guys,
    what would give the best pic quality between these projectors.. Cine7LT or the BG808 ?
    I'm a sony vpl-vw11ht lcd owner, go easy on me, i may take the crt plunge but still not 100% sure.
  2. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I'm no expert but have done a fair amount of research before upgrading from a Sony VW12 to a Cine 7LT. A decent and well setup BG808s will give you a brighter sharper picture and better blacks, but the colours (especially red) will be much better (more accurate) on the 7LT thanks to its colour filtered lenses. Also you don't need a scaler with the 7LT if you feed it a decent progressive scan signal from your DVD player (a Panasonic RP82 in my case), whereas you'll need to budget for a scaler if you go for a 808s otherwise the scanlines would be too visible. The built-in Limo Pro scaler works quite well but is not as good as an external scaler.
  3. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    It also depends on what size of a screen you want. The 7LT will be bright enough for up to 7' wide, but if you want bigger then a 808s would be better.
  4. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,759
    On AVForums
    +569
    thanks godfather.
