Best phono stage under £150
Discussion in 'Hi-Fi Stereo Systems & Separates' started by kstandsteve, Feb 21, 2013.
  1. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    As title really
    My system is Rega Planar 2, ortofon red cart, kenwood 3020se amp.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,446
    107
    Leicestershire, UK
    +480
    Musical Fidelity V-LPS is a good buy. Or the Project range. Or Rega.
  3. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    Been looking at MF and Project ones MF is £120 Project is £79 question is the dearer one worth the extra?
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    You couldpick up an Sony ES amp with a better onboard phono stage than an offboard £150 stage. Also will upgrade your 3020SE (a nice old amp but one that could be improved upon by a Sony TA-F670ES/700ES/630ESD and a few more. Worth reading up on. Sony ES search the forum.
  5. rorackowe
    rorackowe
    Sep 27, 2007
    1,910
    63
    +213
    Just been checking noise floor of my offboard Creek OBH 8se, a pretty good moving magnet solid state phono stage. Surprised to find the Sony (TA F630ESD) was quieter! Difficult to to A B listening tests however.
    That said the amp cost a third as much as the Creek.
  6. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    Cheers. Surprised to hear the Sony has a better phono stage than a dedicated unit. Had a look on auction site and non at the mo. there is a 542ES?
  7. rorackowe
    rorackowe
    Sep 27, 2007
    1,910
    63
    +213
    Not sure it's better per se - is a pig to change the RCA cables behind the unit - but it certainly is VERY quiet re hum and hiss!
    I've had a few integrated amps (NAD, Cyrus low to mid range) and it's quieter (noise wise) than all of them.
    That said it might have a lower output too (SNR relevant there)!
  8. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    In my system the TA-F630ESD was better than a Naim Stageline MM (Linn LP12, Akito, Valhalla, Shure V15 III). I had previously a Moth 30 RIAA phono stage, CA 640P. The nearest to the Sony stage was the Moth 30 but there is a long distance between them time wise. The Stageline was used with a Primare A30.1 II. The Sony ES was a better match with my speakers.
  9. smojphace
    smojphace
    Jan 31, 2013
    12
    Fun City
    Have a look on ebay or some of the HiFi forums for a 2nd hand Graham Slee. For £150 your looking at a fairly new Gram Amp 2 or possibly an older Era Gold.
  10. Arfa
    Arfa
    Apr 25, 2006
    1,077
    London
    +71
    I run a Creek OBH-8SE myself too. Cracking little phono stage for the money. Don't come up too often second hand mind. A new Creek phono amp is quite a bit more though.
    I wrote a article a while ago rounding up all the best choice phono amps for around a £100, both new and second hand. Have a gander.
