Best PCI Freeview Card
Discussion in 'Freeview & YouView' started by LDJ, Apr 10, 2005.
  1. LDJ
    LDJ
    Jun 18, 2003
    590
    +26
    I want to add a freeview card to my PC so i can record freeview on my computer.
    Can anyone suggest the best card to do this? I want an internal card, not external, which seems to limit my options somewhat :(
  2. GrahameD
    GrahameD
    Feb 3, 2005
    301
    Baldock
    +4
    Look at the nebula PCI version.
  3. mjr600
    mjr600
    I've been using this card for nearly a year now and have been really impressed. There has just been a major driver update which has improved picture quality, EPG information and bundled a burner which allows you to record direct to DVD on the fly. It has also received Microsoft Media Centre approval and that should see a number of aftermarket front ends become available.
    Its also a great price at £43 from the link below.
    www.digitalradiotech.co.uk/visionplus_dtv_pci_review.htm (based on the old drivers and front end)
    www.twinhan.com/product_terrestrial_1.asp
    www.cclonline.com/product-info.asp?product_id=657&category_id=76&manufacturer_id=0
  4. GrahameD
    GrahameD
    Feb 3, 2005
    301
    Baldock
    +4
    Nebula even have a usb topup tv cam reader
