Best PC software for controlling kit
Discussion in 'Home Cinema Control & Remote Controls' started by Mora, Sep 16, 2005.
  1. Mora
    Mora
    Jul 16, 2003
    80
    11
    Anyone know the best PC software, for use with a touch screen, to control all the kit.. ie: AV amp, DVD, plasma, etc,etc
    So will need a cable from PC to IR sender inside cupboard.
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    I think one might need to be a little more specific.
  3. bcopping
    bcopping
    May 24, 2005
    506
    28
    Brecon
    +45
  4. bcopping
    bcopping
    May 24, 2005
    506
    28
    Brecon
    +45
  5. AndyR
    AndyR
  6. richardbarman
    richardbarman
    Apr 25, 2005
    65
    If you just mean translating touchscreen commands to IR. What about Xlobby and Girder.
    http://www.xlobby.com/
    http://www.promixis.com/
    Girder is really great, you can open applications and do just about anything with IR translation as well.
    Richard
