Best PAL PS DVD under £150?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stricko, Jan 20, 2004.
  1. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    I'm another Cambridge Audio DVD 57 buyer who is fed up with some of its less friendly "features". Reading some of the older threads, there seems to be a growing concensus that RS are "pushing" the CA range, sometimes at the expense of better equipment.
    Sorry to be asking the same question as others before me, but if I'm going to take back the 57, whats my best current alternative?
    The DVD will be fed via a HK4500 amp and a Pioneer 43" plasma (component link preferred).
    Apart from making the most of the units above, I need DVD-R / RW reading, JPEG, and of course PAL PS. I not that fussed about the DVD-A/SACD side. Budget? The £150 I'm getting back from the 57.
    Your thoughts would be much appreciated..............
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Spend the extra and get a HK DVD2550 for £250 while you still can mate.
    £100 better spent then £150 on another brand X Unit
  3. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    You don't know how hard it was getting the £150 past the domestic management dragon in the first place. Another £100 might just cause it to breath fire again!
    ("what do you mean, upgrade the DVD player? We've already got a DVD player, what do you want another one for etc etc")
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Many like the Sony 730. I have one and find it a bit dark, but I seem to be in a small minority. £149 from HomeCinemaHeaven , though may be found a bit cheaper elsewhere.
  5. mrmc74
    mrmc74
    Nov 28, 2001
    122
    Netherlands
    New HK DVD22 is pal progressive and is available in Germany in Feb. Online price is €219 which is £150
  6. AndrewB
    AndrewB
    Jan 5, 2004
    209
    I'm looking for the same thing and have done some research. I'm about to buy the Sony 730 multi-region for £129.88 from here:
    Techtronics Sony 730
    It has the same Video DAC and picture enhancement gubbins as the very well reviewed Sony 930. PAL and NTSC progressive scan. Seems like a bargain to me...
    Andrew
  7. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Quite like it actually. Have to concur with KraGorn on the dark issue though. Not a problem though, quite like it - in fact as it increases the black level quite nicely on cinema 2, which is about right for my PJ it would seem.
    Not quite the 930 after further investigation. Does not have adjustable gamma range on the memory video option but I never used that on my 735 anyhow.
    A bargain for £130.00.
    Cap:smashin:
  8. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    This may seem like a minor quibble, but I really do need JPEG / Picture CD capability. It's the one benefit over my old player that really excited the family. Does the Sony 730 support this, I can't find reference to it on either suggested link.
  9. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    Andrewb' i just bought a 730 and may be about to get a great deal on super dvd player. So i will have it for sale soon. So if you are interested give me a pm and i can save you a few bob
  10. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    Sorry, I'm only posting again to keep the thread visible (first page!)
    I've got votes for the Sony, anybody else got any ideas. What about the Yamaha DVDS540 (no obvious problems), Pioneer DV565 (no PAL PS?) or a Marantz 4300 (no Jpeg).
    Anyone know if the Sony does JPEG. How does it rate vs the Yamaha?
  11. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Yamaha player are consistently high quality and don't get the press they deserve, there is a PS model for 150 rrp but have seen it locally for MUCH less
  12. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    I might be tempted to go up to the HK if it had JPEG, but the specs say it doesn't.
    Any more bright ideas?
  13. chrissandgate
    chrissandgate
    Yamaha 540 is a corker, it'll do the jpegs and will even play music over them as well ( if you have some 'slideshow' type software on your pc. It does PAL and NTSC prog scan and is quite a good cd player to boot. Don't bother paying for a multi-region machine as the crack is dead easy. Look to pay about a ton, and either get a component cable or a load of DVDS with the change.
  14. Seb1
    Seb1
    Sep 29, 2002
    110
    Yep, I totally agree. I bought a Yamaha 540 (Multi Region) and its the mutts nuts! It cost me £109 which is an absolute bargain.
    I was very impressed with the way it plays CD's. It's so much better that the Toshiba SD330 I had before it...
  15. stricko
    stricko
    Jan 20, 2004
    284
    Lambourn
    +4
    I'm getting votes for Yamaha, Sony, and HK. Also Limit being pushed on a different thread.
    Any more for the skylark..............
  16. Timh
    Timh
    Sep 14, 2000
    4,819
    Altair-4
    +140
    The Yamaha s540 that my Brother owns has bad ghosting and a very poor de-interlacer, but others seem to be pleased with it.
    Out of the Sony and the HK I would go for he Hk as sony seem to have problems with their optical blocks failing prematurley, but the Hk is £100 over your budget.
  17. Beastie Boy
    Beastie Boy
    I have the Yamaha S540 and am very pleased with it, certainly no signs of ghosting.
    As regards the de-interlacer, if you are playing PAL discs then it is simply a matter of weaving two fields together. Even the most basic de-interlacer can manage this. If you have NTSC discs then it becomes more difficult due to incorrect flagging in the video stream, among other problems.
    Cheers, Beastie.
  18. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    I thought it was Pal PS (3:2 pull down) that was harder to do than NTSC PS (2:2 pull down) ? :confused: It's certainly the case that Pal discs suffer more from incorrect flagging.
    Croc
  19. Beastie Boy
    Beastie Boy
    I believe it's the other way around. 2:2 pulldownd for PAL (since it's 50 fields into 25 frames / second), and 3:2 pulldown for NTSC.
    Please correct me if I'm wrong.
    Cheers, Beastie.
    EDIT: I think my first post was a little too brief. The type of material I'm talking about is footage captured from a film source, ie. movies. These progressive frames are then simply split into odd and even scan lines (fields). The conversion back to progressive is simply a case of recombining the line alternately (weaving).
    Truly interlaced material, eg. TV broadcast or camcorder footage is a lttle different in that it is composed of 50 fields per second, captured at 50 fields per second. This is much more difficult to de-interlace without causing artifacts and, IMHO is best displayed interlaced on an interlaced screen (CRT).
