Best Pal Prog player to better my ageing 737......
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lighty, Jun 22, 2003.
  1. Lighty
    Lighty
    Mar 7, 2002
    2,710
    East Yorks
    +111
    i'm open to opinion on a good pal prog player to better my 737 - getting on a bit but still very good in my eyes....
    i demo'd an 88+ and wasn't blown away but it was straight out of the box and my friendly dealer tells me they need running in.
    will a HK 525 / philips 963SA / pioneer 757 (soon) / Arcam 88+ show big improvement?
    just really DVD-V at present thru a Sim HT200DM.
    SACD and DVD-A not an issue yet but would be a bonus
    video quality is what counts!
    thanks All
    Lighty
  2. Zig
    Zig
    I am very happy with my 757.
    I would imagine it would be a worthwhile step up but I'm sure a demo once the update is out will help you decide.
  3. puddleduck
    puddleduck
    Jan 24, 2003
    1,814
    48
    Lake District, near as dammit
    +50
    I went from a 737 up to a Philips 963SA and couldn't be happier.
    Main reasons for me were PAL-P, lack of chroma bug, and the EXCELLENT Redbook CD playback.
    The 737 probably has better interlaced output IMHO though.
  4. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, I have a Sim2 DMF and a DV88+ and the difference between my old tosh 210se and the progressive mode in my dv88+ is great - the picture is very film like and the detail is greatly increased.
    The DV88+ is a lovely player in progressive mode and good for cd sound as well - if you are not so interested in the sound though you may want to check out the pio or look at the arcam that is the model higher second hand (which I wish I had).
    CaM
  5. totem
    totem
    Dec 3, 2002
    26
    3
    London
    I very much like my pioneer 757, not PAL progressive, but may become so (see threads), however i find the pal output very good even though it is not progressive. the cd sound could be better, but you can add a stand alone player such as the arcam cd 72, as i have done, giving a total of about £1000. this gives me a good all round solution
    my setup: Panasonic AE300, Sony 32FQ75, Pioneer 757Ai, Arcam CD72, Denon AV 11SR, Monitor Audio GR20/Centre/10 & VDH cables
  6. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    I also went from a 737 to 757. Tested Arcam, philips and Denon too. In my opinion the 757 is absolutely terrfic value for money against features available. You can search and find comments and details given in other threads since Jan'03. There is no better high end DVD player in interlace mode (hard to separate from progressive). It has excellent NTSC prog scan and as mentioned you can also upgrade it for PAL soon. Finally, if you check this forum you will find that the 757 has the least (if any!) problems reported against the other three. Hope it helps... test to make your decision!
