Best option to replace HDMI lead
candg
2 years after considerable effort in fitting a 10 metre HDMI lead to my 1080p projector the lead has now died. It would be Extremely difficult to replace this. I am wondering about HDMI over CAT 5 cable or wireless HDMI. Any thoughts on best option for a realistic price. ?
Many thanks
Graham
Joe Fernand
AVForums Sponsor
candg
Thanks for your reply Jo. I do,nt need audio or IR as it,s to a pj. Is there a cheaper option than the one you suggested ?
Cheers again
Graham
Joe Fernand
AVForums Sponsor
I doubt many Extenders won’t support audio – HDMI audio is embedded into the video signal and decoded by the Sink device so not much extra burden on the extender to include it or not.
There are lower cost and non IR units around – I’ve linked to the units we have experience of!
Joe
PS It's worth noting too that a lot of the lower cost Extenders require you to have a minimum of 15m of cable between the Tx (transmitter) and Rx (Receiver) as they don’t auto equalize for short or long cable runs.
candg
Hi Jo, I am thinking about the Octava but still have some concerns about what the quality of CAT 5 for HDMI. Do you have a return policy if I am not satisfied with the results ?
Graham
Joe Fernand
AVForums Sponsor
If it doesn’t do what you require send it back to your supplier for a full refund – you won’t see any difference between HDMI direct (using a short HDMI<>HDMI cable) and the Octava HDMI over twisted pair solution; there is no compression in the Octava solution.
Joe
