Best operating system for HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Jun 13, 2002.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Hi Chaps,
    Maybe a dim question...But what do you think the best or most stable operating system would be for my HCPC?
    I have both WIN2000 and WIN98 disks?
    Chris
  2. paiger
    paiger
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I use W2K not been a problem so far.
  4. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,314
    Berks, England
    +141
    Hi Chris,
    If it's really only a choice between Win2000 and Win98 (and you won't buy XP), then check the Win98 is the Win98se version.
    I don't think some directx or digital audio things work properly on the original Win98 or Win95 versions.
    I still use WinMe myself, but WinXP home is about the same price now, so I'd probably jump to that if in your shoes and doing a build from scratch.
    What DVD software?
    One thing if you are planning on doing large video capture is Win98 doesn't allow files to be >4GB in size because it doesn't support the later NTFS file system which Win2000 and XP do.
    regards,
    Rob.
  5. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    I would use win 2000 rather than your win 98.
    As long as it is a clean install, followed by a visit to windows update site for the latest patches, will be just fine.
    Good luck,
    Mark.
  6. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Cheers Fella's.
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    All the OSes have issues, depending on your setup one will work better than the others. I found 98 and XP to work best.
  8. Doubledoom
    Doubledoom
    Win98 has better hard disk performance but Win2k/XP (XP is really only an update of Win2k) is far more stable. You could leave 2k/XP for weeks without any slow down.
    Win2k/XP doesn't like most parrellel port connected items whereas 98/ME does.
