Best method for connecting PACE set-top box to Plasma
Discussion in 'Plasma TVs' started by AndoverRed, Sep 5, 2005.
  1. AndoverRed
    AndoverRed
    Sep 24, 2004
    248
    Andover
    +5
    Unfortunately, I presently have a legacy ntl PACE set-top box for viewing cable. :mad:
    I am soon to purchase a Plasma (or LCD) display and would like advice on the best method to attach the PACE box to the display. The obvious (and least preferred) option is SCART-to-SCART, but I am considering a Panasonic PWD/PHD8 panel.
    I would look to separate the audio (to Arcam receiver) and video (to display).
    What are the alternatives?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,584
    3
    North Yorkshire
    +271
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    That works brilliantly with the Panasonic, if you have component video switching on that Arcam, you might consider the YUV converter instead, it will be simpler to operate the system. It will still be fine when and if they upgrade you to a Samsung box.
