Best memory stick manufacturer for the price??
Discussion in 'Photography Forums' started by Bigweed, Oct 4, 2004.
  1. Bigweed
    Bigweed
    May 5, 2004
    120
    16
    Bournemouth, UK
    Hi, I have just bought the Sony DSC-W1 camera, and was wondering what the best memory stick manufacturer is at the best price?? Reliability and speed important. Also, the best place to buy them from??
    Also, there are a couple of versions of the memory stick- can anyone tell me which is best, ie memory stick, memory stick pro, memory stick duo, memory stick duo pro??? Cheers for everyones help
    Bigweed
  2. chicken balti
    chicken balti
    Bought a SanDisk 256mb Memory Stick Pro for £44. Result.
