Best media for an HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by overkill, Nov 19, 2003.
  1. overkill
    overkill
    Nov 6, 2003
    11,848
    Murkeyside
    +1,207
    Can anyone direct me to the page which lists the media the HS2 is happy with? I found it (once!) then foolishly forgot to bookmark it! Sob!! If no-one knows where it is, feel free to list any personal preferences!!!
    Thanks!
    Oh BTW where do you guys get your media from?
  2. john hannam
    john hannam
    Oct 11, 2003
    lincoln
    Panasonic discs never fail on my E100 or my E50
  3. marky_h
    marky_h
    Dec 19, 2002
    369
    Hampshire, UK
    +22
    overkill, it's not this one is it? I'm considering an HS2, and happened upon it today.
    Mark
  4. overkill
    overkill
    Nov 6, 2003
    11,848
    Murkeyside
    +1,207
    Ah-ha!! Knew i'd find it!! Its a black hole on the web called:-the world wide web HS2 pages Theres an faq on the HS2 towards the bottom of the page. It lists media there. Use the forums as well as these guys list media that works with their HS2's.
