eastman3000
Hi All!
After some help please:
What is your budget? up to £900
What size laptop do you want?
(In terms of screen size)
13 or 15"
Do you have resolution requirements?
No
Do you want a matte or glossy (reflective) screen?
Not sure
What will you be using the laptop for?
For example, Browsing, Word Processing, Video / photo Editing,
If you will be gaming, what games do you need to play?
n/a
How long does the battery need to last?
Very good up to 4 hours minimum
Does it need to be portable?
Yes -
Do you require Blu-Ray?
No
Do you require HDMI output?
No
Do you have a preferred brand?
Asus, Toshiba,
Are there brands you would prefer to avoid?
Would you be happy with a refurbished laptop?
No
Any other details you feel necessary - USB 3.0 - Dedicated graphics for video
/ photo editing
I thought of the following for a starters - Toshiba Satellite Pro R850-143 PT52KE-007010EN
However not as light as I want....
any others?
13 or 15"
No
Not sure
n/a
Yes -
No
No
Asus, Toshiba,
No
/ photo editing
any others?
