Question Best LED spotlights, which are also best value
BIONIC MAN
LED spotlights, as there's so many on the market need some advice on what to go for :thumbsdow also best value.
Cool White for Kitchen, bathrooms & Warm White for living and bedrooms
Help for any help / advice
:thumbsup:
EndlessWaves
Are you after the fittings, the bulbs or integrated units?
It sounds like you're after indoor spotlights rather than outdoor. Are you after recessed (angle adjustable downlights) or not?
Maverick567
I have just fitted Luceco FType’s in both bedroom and downstairs loo, really well built and easy to install. They offer loads of different options when it comes to colour including colour changing.
BIONIC MAN
They look the part thanks for that :)
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
