Best leads for Hitachi pd5200
Discussion in 'Plasma TVs' started by rudy, Aug 20, 2005.
  1. rudy
    rudy
    Jan 2, 2005
    499
    I'm looking at the profigold leads; scart to scart and scart to component. My DVD player has digital optical output; can I make use of this instead?
  2. camorra
    camorra
    Aug 12, 2005
    625
    +29
    The digital optic out is for audio only!!
    If your DVD player has component output use that, and preferably set to progressive mode (if your DVD has that function). If not you will have to connect it in RGB mode (via scart as you said).
    Cheers :hiya:
  3. rudy
    rudy
    Jan 2, 2005
    499
    Thanks dude
    So component out on my dvd is the the 2 audio sockets and the 1 video? sorry to sound thick
  4. loadsofleads
    loadsofleads
    I have a Supra HDMI-DVI cable from my DVD to the 5200 and the pic is sweet. :thumbsup:
  5. rudy
    rudy
    Jan 2, 2005
    499
    Just dug out some gold plated s video leads and a set of audio leads and it seems to be ok for now. My dvd does'nt have hdmi unfortunately. I need to upgrade to something half decent
  6. camorra
    camorra
    Aug 12, 2005
    625
    +29
    A Denon DVD-1910 with DVI output and upscaling would do the perfect job !!
    Cheers :hiya:
  7. longleyc
    longleyc
    Im a bit confused rudy.
    If the tv and dvd have the Y Pb Pr (Green, Blue, Red) Component then get/use the component leads.
    If not, as stated, you will have to use the RGB Scart mode from DVD to TV.
    You can use Optical connection for 5.1 sound. Might be described as Toslink too.
    Or you can use Coaxial Electrical for sound too. That looks similar to an RCA jack plug, but both DVD and TV must have it.
  8. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    1 video socket is composite out (the worst possible connection) with the two audio sockets for stereo sound.
    Component out is three sockets usually, red, green and blue.
    John
