best lcd tv method
Discussion in 'LCD & LED LCD TVs' started by alanpg1, Nov 25, 2004.
  1. alanpg1
    alanpg1
    can a lcd monitor be fed sat/cable rgb tv signal direct, or is it better quality through tv card.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Hi Alan, welcome to the forums :hiya:
    If you wish to watch TV on your monitor, the best option is to use a TV tuner card. The Nebula DigiTV card is excellent and receives digital terrestrial broadcasts. If you wish to use the monitor with the PC switched off something like the Pro-V would suit you better. Hope this helps.
  3. alanpg1
    alanpg1
    ta
    alan
