B
butterflies
What is the best LCD for watching SD material?
More than likely most 1368 x 768 HD ready sets..... Not Full HD...
Although my Z series Full HD 37" displays a mean SD signal over SKY.
Can't you just (as with a computer monitor) change the resolution?
Do you say that 768 LCD's produce better SD picture then HD?
By HD I assume that you mean 1920x1080 'Full HD' sets rather than barely HD (aka HD Ready) sets. Despite various claims on this group, there is no evidence that barely HD sets display SD better than full HD examples. In practice, the higher the resolution, the better the remapping that the scaler circuits can achieve, as there is more chance of there being a pixel available in the correct position. This assumes that the scalers are of equivalent quality. Of course you will pay slightly more for the 1080 set, but this difference will all but disappear on sets of 37inch and above soon.
The important thing in comparing any sets' SD performance is to view from the correct distance for SD which is dependent on the screen size.
runas
