Best input for dvd on VIERA plasma
Discussion in 'Plasma TVs Forum' started by Funkybase, Dec 17, 2004.
  1. Funkybase
    Funkybase
    Jul 21, 2004
    69
    I have a Denon DVD-2910 that is connected to the component input on my 42" Viera screen. Is this the best input or will picture be improved using the RGB/Scart input? I'm currently using progressiva scan in the dvd player.
  2. astirling
    astirling
    Oct 1, 2004
    1,824
    113
    Dunfermline
    +561
    No....Using RGB would be a step back imo. And a fairly big one at that if you're using progressive scan at the moment.
  3. Funkybase
    Funkybase
    Jul 21, 2004
    69
    Thank for you reply, good to know! :thumbsup:
  4. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I have a Panny e55 dvdr and viera. My best pq from dvd's is component with progressive turned off. Try it, I understand that the deinterlacer in the viera works better than most in dvd players. Don't know about your Denon tho.
  5. Funkybase
    Funkybase
    Jul 21, 2004
    69
    The Denons deinterlacer i a Faroudja chip, I think the dvds interlacer is better than the Vieras in this case?
  6. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Probably so, you need an expert. :)
    ps. No harm trying and making your own mind up.
  7. Anthall
    Anthall
    Oct 27, 2004
    220
    Kettering
    +4
    I got a question???
    Im connecting my home entertainment system (all in one) up to 42" plasma
    using component and scart. The dvd player doesn't support PAL
    progressive, so it's turned off, shall i throw my component leads away or are they still
    providing me with a better image than say RGB Scart?
    Sorry for stealing thread and putting my problem on here :blush:
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    All things being equall, the componenet connection should still be better than rgb scart. The only way to tell , is try it on both and then pick the one you preffer. After all , your the one watching the thing :)
