Best image quality on sky + question ?
Discussion in 'Sky Digital TV Forum' started by Throttle, Oct 14, 2004.
  1. Throttle
    Throttle
    Sep 28, 2004
    1,826
    Leigh
    +108
    I recently got a Hitachi 42PD5200 which im happy with and i have it linked through the tv's scart using the standard supplied scart lead atm ...
    But what would give me the best possible picture quality based on my setup would http://www.tvcables.co.uk/cgi-bin/tvcables/PGV372.html improve my picture even more or would it be same quality as scart as it would have to through the sky scart output ?
    Any info please :laugh:
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Those are component TO scart, and of course there's no component out from Sky +. JS do a scart to component convertor, but I doubt if there's much PQ improvement, it's more down to the issue if you don't have enought scarts, which may be the case with the 5200 as it only has one...
  3. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    My V2 sky+ has a 1 scart RBG componet output, but its not the same signal as those leads. I bought a synblaster kit from keene. I got it to connect to my PJ £100 ish
  4. Throttle
    Throttle
    Sep 28, 2004
    1,826
    Leigh
    +108
  5. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Generally recognised on these forums that the best PQ from Sky+ is acheived by using a JS Tech Scart to VGA convertor, and therefore connecting to your plasma via the VGA input.
  6. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    Why does it just say plasma, don't they work with LCDs?
  7. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    I'm sure they do. I was just speaking from personal experience.
  8. Throttle
    Throttle
    Sep 28, 2004
    1,826
    Leigh
    +108
    Thanks for the info steve :thumbsup: I'll try get Js tech scart to vga convertor asap :D
  9. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    sorry, I didn't mean your wording :blush:
    But on the JStech website, it only mentions plasma thats all...
