Best headphones for iPod?
Discussion in 'Headphones, Earphones & Portable Music' started by SqOne, Feb 6, 2009.
  1. SqOne
    SqOne
    Right, the situation goes I'm looking for a nice pair of headphones which are comfortable in the way of the padded ears (if that makes any sense?! as in the soft leathery feel...), obviously a pretty good sound quality and FINALLY, a reasonable size lead.
    I've looked at lots of nice headphones that look top, but they're leads are around 2.5-3m so probably designed for studio use, does anyone know of anything more suitable for a commute?
    When I say about the padded ears i'm thinking through common sense and past experience, earbuds seem to get quite uncomfortable after a while so I'm presuming closed headphones would suit me better. Also they're going to be used on flights so do closed cut out sound better?
    Look forward to your replies & thanks in advance!
  2. chubbs1981
    chubbs1981
    Jan 1, 2009
    30
    i have the sen 465's for my ipod, very soft and comfy for my battered cauliflower ears anyway :rotfl: however they are not great for anything but sitting or walking as they tend to move around if you do.
    for the gym i have a cheap cheap pair of plug in ones with ear loops that cost about 9 quid from argos. sound is terrible but i don't care anything is better than the gyms choice of girl band drivel
