Best HDMI cable?
Discussion in 'Cables & Switches' started by tee, Oct 20, 2005.
  1. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Looking to connect my incoming Pioneer PDP-436XDE to Denon 1920. Any suggestions?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,981
    The Borders
    +3,592
    Hello tee
    What cable length are you after?
    Best regards
    Joe
  3. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    0.5 to 1m - something like that. Not long
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,981
    The Borders
    +3,592
    Hello tee
    A 2m Molex HDMI can be had for sub £20.00 and offers very good performance for the money - some say as good as you'll get as HDMI over short distances should work on all HDMI cables with the same end result.
    If you want to spend a bit more and have a cable with a heavier grade of cable, better tolerances and proven connectivity with the highest resolution signals then a BetterCables Display Magic 1m HDMI cable is worth considering at just over £55.00.
    See http://www.bettercables.com/hdmicables.html
    There are plenty of other options and plenty of Cable suppliers with Banner Adds on AVForums.
    Best regards
    Joe
