Best graphics card? Will it do what I want?
Discussion in 'Desktop & Laptop Computers Forum' started by hoyin, Jan 24, 2005.
  1. hoyin
    hoyin
    Ok I will be connecting my HTPC to a Sharp 26" LCD. Which means I will have true 16:9 and 1:1 pixel matching.
    However there are many things I want to take into consideration:
    1. What graphics card will be suitable as my LCD will need a DVI cable about 12-15m in length. I have heard some card drivers cannot handle this. Could you suggest some that are capable of doing this?
    2. I am hoping to use my work PC as my HTPC as well. However I forsee some problems.
    Currently I am running a dual 17" LCD display. 1 from an AGP Geforce mx4 and the other from a PCI Geforce Mx4.
    Now I am fine with replacing the AGP card with a more powerful one and one with a decent DVI out. But the problem I forsee is that I will not have the LCD tv on all the time. Am I able to display a different desktop on the DVI out put and the VGA output?
    What happens if I wish to work whilst the TV is on? Will I beable to do this?
    It would mean running two desktops from one graphics card, I don't think this will be possible. This would mean I would have to have a seperate PC just for HT?
    Something I am trying to avoid.
    Anyway, thoughts and suggestions gratefully appreciated.
    Regards,
    Ho yin
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    AFAIR You can easily run two desktops from one graphics card - a mate used to have a Dual Head Matrox card that enabled that quite merrily. My PC has a Nvidia 5900XT in it and I can have multiple desktops - One using the DVI and one using the standard VGA connector (I just had a quick look).
    So basically you shouldn't have any issues with getting something similar and running a PC Desktop on one output and the Movie output on the other :thumbsup: (I just don't use my PC that way - so I can't physically confirm it - but it's all there in my config)
  3. hoyin
    hoyin
    Thanks,
    But I did have a dual head graphics card but I binned it infavour of having two seperate video cards the reason being was that the desktop was shared over two monitors. So when you maximised a window it spread across both screens.
    Whereas now when I am using two different graphic cards it treats them as two seperate desktops, when I maximise a window it fills one screen only.
    Hence my question .. does the DVI output a seperate desktop or just an total extension of the main desktop.
    Will the Nvidia card driver support 15m of DVI cable?
  4. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    The driver I'm using enables Multiple Desktops - not just an extension of one across two screens. I can't unfortunately check beyond this as the driver detects the screens attached to the card - and i've only got one! This web page seems to explain the multiple desktops as you would probably use them. As for a 15m cable working - check this link out, it may assist
    http://www.ramelectronics.net/html/DVI_cables.html
    Again - I just use my PC as a PC, not for anything else :thumbsup:
