Best Graphics card for MCE HTPC?
Discussion in 'Microsoft Windows' started by sted, Mar 31, 2005.
  1. sted
    sted
    Jan 20, 2004
    79
    Can anyone suggest the best graphics card for an HTPC running Windows Media Center 2005? Will be outputting to a 32" CRT . . .
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    If it's only to be used for media output then anything silently cooled will do the job.
    These or these or for AGP these should all be fine.
  3. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
    Or.... see the thread below (Gigabyte GF6600GT) fanless, powerful and nvidia pure video post processing.... (allegedly - not got mine yet!)
  4. sted
    sted
    Jan 20, 2004
    79
    Cheers. Yep, only to be used for media output - xbox caters for my gaming needs! So i guess the question now is whether it's worth shelling out for the more expensive Gigabyte card. I'm wondering if i wouldn't notice any picture improvements as i've only got a CRT?
  5. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Not for just video. The only case for spending the extra is if you could need/use dual DVI outputs on the card, then you would have to spend more and get a better card. You could get away with a mainboards onboard graphics but this will eat up some of your main memory so for the cost a separate card is more cost effective. The cards will also be more than adequate for office type apps just make sure system memory is a min of 512.
  6. sted
    sted
    Jan 20, 2004
    79
    Ok, thanks. One more question - will a PCI express card work in a standard PCI slot. The reason i ask is i want to test on my old motherboard before i buy a new one . . .
  7. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
    No!
  8. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    No, you can get with difficulty a pci video card but dont bother, you may as well go with onboard graphics, PCI-Express is compleatly different to the PCI slot which is device input/output medium. :)
  9. sted
    sted
    Jan 20, 2004
    79
    ok, thanks. my problem is i don't want to shell out on everything before i can confirm that the picture looks ok on my tv. hmm. just out of interest what are your thoughts on the points above? are you in the 'cheap is fine' camp or 'it's worth the extra money' camp?
  10. sted
    sted
    Jan 20, 2004
    79
    yep, trouble is i don't have any tv out at the moment and want to test what media center looks like on my TV - so i guess i need to find an old PCI card with an s-vhs out . . .
  11. Spacecat
    Spacecat
    Apr 1, 2001
    2,898
    London
    +583
    trouble is an old video card wont be as good as a new video card so you are not solving your problem
  12. sted
    sted
    Jan 20, 2004
    79
    Here's another one for you all - does a graphics card exist with component out? I only want to connect to the tv component in or scart sockets as the s-vhs socket is at the front. I was ready to buy an s-vhs to scart lead but am now wondering if i can use the component in?
  13. lisag
    lisag
    Jul 14, 2004
    5,890
    Essex
    +368
    Yes many cards have a component dongle that can be added, not sure which ones but definitely the Gigabyte one mentioned in a separate thread.
