Best graphics card for a 300W PSU?
rorackowe
Is the PSU any particular brand? Some models are more likely to be able to output true 300w than others. Does it have a PCI express connector on it? And what is the stated +12v output on the PSU case?
What do you use the PC for? Is it for movies or gaming? What size case? Do you have a spare PCIE x16 slot on your motherboard? Full height, low profile and what length? Sorry for so many questions, just helps narrow things down.
blackanchorage
blackanchorage said:
Don't know what you've got already, but there are some mid-range ATI cards with low power requirements. I have a Dell 300W power supply, and it looks like it would handle a HD 5670 card. But as rorackowe says, it depends on the PSU quality.
power calculator: eXtreme Power Supply Calculator
benchmark: PassMark Software - Video Card Benchmark Charts - Video Card Model List
power requirements: The Truth About Graphics Power Requirements V2 - Atomic 3.0
Regards
Already got the 5670 and it works very well :)
Thanks anyway mate.
Sent from my HTC Desire using AVForums
