Best GPU for Q6600?
Hi peeps, just wondering what the best GPU is that the Q6600 can wok with without being a bottle neck in modern games?
Thanks :smashin:
paulktreg
Not that simple. What resolution is your gaming monitor? The Q6600 is still a capable processor but low monitor resolutions will keep it occupied whilst higher, 1680 x 1050 for example, rely more on the GPU.
@1080p
Im just wondering because I want to ge a GPU [for my younger brother] but theres no point getting the best one I can and it being bottlenecked by the CPU when a lower end model would perform exactly the same.
Atm im thinking a 6950 or 5850. Wont be getting for a while
Greg Hook
Moderator & Reviewer
PCplod said:
@1080p
My last PC coped fine with a GTX460. Have you overclocked the CPU as it will go to 3/3.2 very easily providing you have a good cooler?
LJx
a Q6600 is not going to "bottleneck" any graphics card so feel free to get him anything. Very few games are restricted by having a CPU like that
shadowboxer
At stock setting the Q6600 will bottleneck the high end graphics cards but if you can get yourself a cheapish cooler and overclock to 3.0-3.2GHz then it will eliminate the bottleneck.
Depending on budget, I would go for;
£130-140 - HD6870
£150-160 - GTX560Ti - Here + free game.
Circa £200 - 2GB 6950
Thanks guys, He hasnt yet got a Q6600 and is running on an old Pentium D atm [although on a new motherboard with DDR3 RAM] but im looking to upgrade it in a month or 2 to a Q9550/Q6600 and a 6950 [for the 2gb Vram] based of your advice [hopfully the 6950 will have dropped in price by then due to the 7*** series] Thanks
shadowboxer
Should be a fair few 2GB 6950's appearing on the classifieds in the next month or so as people look to upgrade to a 7950/7970. Good time to pick up a bargain. I wouldn't hold your breath for retailers to drop their prices that much.
Greg Hook
You'd need something better than a Q6600 to cope with a GTX580. You are talking i5 to get the best from that.
Smurfin
£130-140 - HD6870
Will a stock Q6600 bottleneck a HD6870? If so, can you recommend a cheap cooler for me to add please? :)
Greg Hook
A Q6600 is really easy to overclock. It is one of the best CPUs for this. You can easily get to 3ghz with a decent cheap cooler. Noctua are good for this sort of thing, but anything that isn't a complete piece of crap will be fine.
shadowboxer
It'll be marginal I think at stock settings. The best bang for buck cooler is the Gelid Tranquillo for around £25.
