Best Freview/Encoder Card?
Axion
Basically i have two choices:
1. A freeview tv card & encoder on one card
or
2. use a freeview box hooked up to a dedicated encoder card
two questions really:
1. which setup is best?
2. within each setup, whats the best hardware?
The Hauppauge cards seem to be quite popular, but there loads of them :) what should I look for in a card (spec-wise) and whats best really?
Thanks!
MarkSS
A freeview card should provide the best results as its digital all the way. Using an external freeview box means your receiving a digital signal, outputing an analog signal, capturing that and encoding to digital.
I use 2 Cinergy 2400i dual cards, very happy with them myself but apparently lots of people have had trouble using them with MCE. Theres a long thread on the subject on the forums somewhere.
