Best freeview receiver ?
Discussion in 'Freeview & YouView' started by Gliese 581c, Nov 11, 2004.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    sky is doing my b0ll0x in, so im cancelling and just going to go freeview for a while, whats the best freeview receiver going at the moment ? Pic quality is important to me.
  2. Giles
    Giles
    Jul 25, 2000
    65
    UK
    If you are not interested in TopupTV then I would personally get a Sony VTX-D800.
    Sony have supported this box very well so far in my opinion. I cant fault the picture or the speed.
    The box has RGB scart out, optical out and has a competant and quick 7 day EPG.
    Check out http://www.npe.sony.co.uk/index.html
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Look at the Freeview PVRs
  4. Giles
    Giles
    Jul 25, 2000
    65
    UK
    That is a valid point Arcam, do you know what route you want to go down? Do you need a PVR or topuptv or both?
  5. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    to be honest, recording hasnt really interested me, with having sky for so long everything is repeated every 2nd day anyway hehe.....still though, im not fussy about pvr. and topuptv, there's no channels worth watching on there just now (not sure if more will be added) but i think im after a bog standard freeview box... the sony's the best then ?
  6. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Nah, the NetGem iPlayer is best - run component straight into your PW4 :)
  7. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    component's all tied up with my dvd player im afraid. rgb through the vga converter box for my sat box.
  8. hammy2891
    hammy2891
    netgem for sure !
    not only a good looker but component output,optical output + soon to be updated with 7 day epg
    besides which its only £50 from makro :smashin:
  9. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    thx chaps, i'll check it out.
