best freeview box with component output
Discussion in 'Freeview & YouView' started by peahead, Oct 26, 2004.
  1. peahead
    peahead
    Dec 14, 2002
    3,016
    St.helens
    +389
    hi im after a freeview box with component output are there any out there because would like to get the best picture possible. :eek:
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,119
    Southampton
    +264
    I think you'll find that such a beast doesn't exist.
    As far as Freeview boxes go,the Sony seems to be very well rated amongst those members on this forum,that have had expierence of them.
    HTH
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Only the Netgem IPlayer
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    .. and to pre-empt the inevitable "but I looked on the website and it only has a scart socket" post .... the iPlayer outputs component thru it's scart, you'd need an RGB scart to component cable.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,468
    Rainham Essex
    +2,477
    And TBH unless connecting the Freeview box via an AV receiver etc for video switching there is no need to have component outputs. I would think there will be very little, if any difference in PQ between component & RGBs (scart) as unless going through a video processor you are not going to get a progressive scan image from Freeview even via component.
    Mark.
  6. hammy2891
    hammy2891
    very true the netgem does output component through the scart and it makes a massive difference when fed to my pj :laugh: ,not only the pq but the menus look superp well worth the extra premium + you get internet access too :clap:
  7. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    This is assuming that the scart input is as capable as the component input on your display device. Which is not always the case.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,468
    Rainham Essex
    +2,477
    True, but there are also cases where S-Video is better than RGB, but on a level playing field this is not the case.
    Mark.
  9. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,117
    Leicester
    +48
    Broadband at that.
  10. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I hope you can use eg Scart to 3RCA lead. That's what I'm planning to do.
  11. hammy2891
    hammy2891
    not sure about scart 2 3rca,i'm using scart 2 3rca adapter onto a 3rca 2 hd15 as my pj hasn't got component(3rca) input :thumbsdow
    not only broadband :smoke: but wireless broadband at that :clap:
  12. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,117
    Leicester
    +48
    Have you got the latest software from the Forum?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  14. hammy2891
    hammy2891
    not as yet don't c the point as it doesn't include the 7 day epg
  15. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,117
    Leicester
    +48
    There are a lot of bug fixes and Teletext works properly now.
    I use the Radio Times site for a 14 day tv guide for now, which works well.
    It's a beta release at the mo.
  16. hammy2891
    hammy2891
    i think we've gone off topic here abit, apologies :oops:
    will download when full version is available as no serious bugs,touch wood
  17. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    Hornydragon: here's a more challenging one for you.
    I was being slightly misleading for the sake of simplicity :blush: I will actually be needing SCART to BNC component. I've not found one yet (although I have found scart to VGA which I could use).
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    be careful scart to VGA (RGBHV) is a difficult beast..... have you a link? I would a either buy scart to RCA and 3 BNC to RCA adapters or cut the RCA's off and put BNC's on.
  19. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    although I meant BNC when I said RCA, I didn't mean RGB when I said component. I meant YUV which I believe the panny Min D-sub takes (?).
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes it does on PW6 and additional boards for PW/PHD range
  21. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I misread the scart to vga at the bottom of http://www.beststuff.co.uk/superior_leads.htm (it is RGB)
    So now I haven't found YUV SCART-BNC or SCART-MiniDsub for my (imagined) DVD player. I'm determined to do it without the RCA/BNC adaptors.
    Do DVD players put out RGB?
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    whoa.....hold on there cowboy netgem is a very rare case component via scart....PW6 is rare component by 15 pin D-Sub....
    DVD player will most probably out put RGBS not compatible with RGBHV (VGA) without a Sync seperator. Which is what JS RGB>VGA does
  23. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    Lets take stock. I've bought the pwd6. One plan is:
    DVD player YUV out (3RCA to 3BNC on pwd6)
    FV - Netgem YUV ( scart-Dsub ) or SVID
    or FV Pace Twin YUV? (scart - Dsub) or RGB? (scart-Dsub)
    Does the panasonic use the same pins for YUV and RGB on the D-sub? ie can I use a scart-Dsub lead regardless of whether the Pace is putting out YUV or RGB ?
  24. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Pace Twin does RGB sync on composite
    SVid is evil use RGB or Component
  25. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    FV component ONLY NET gem to use PAce tein would need an RGB>VGA/Component converter... AS RGB>YUV converter is £150 ish i reconmend the Panny E55 DVD recordr as this will accept RGBS from FV and OUTput YUV from DVD and FV box while DVDR is on...... Allows you to use live pause on DVD-ram etc
  26. BIGDAZ
    BIGDAZ
    Sep 7, 2004
    7
    Try looking at the Humax DV1000T freeview/DVD player. This has Component and prog. scan. This unit can also be made multi region. The freeview side is fast with great features. I am only using RGB scart at the moment and impressed by the picture and sound quality. Optical out Dolby Dig. and DTS.
    Check Humax website then buy from Dabs.com for £89.99
    I have posted multi region hack on this forum.
    Hope this helps :smashin:
  27. Cool Man
    Cool Man
    Hi HornyDragon, when you recommend the Panny E55 DVD recordr as this will accept RGBS from FV and OUTput YUV from DVD and FV box while DVDR is on..
    can you clarify what cables will goto the plasma ? and what will need to be connected to an AV amp
    many thanks
