Best for my budget
Discussion in 'Plasma TVs Forum' started by sparkymark75, Oct 19, 2004.
  1. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,122
    Fife
    +686
    I have a budget of £1500, is the LG RZ-42PX11 the best I can get for this price range?
    It'll be hooked up to a Sky DigiBox so not fussed for a tuner.
  2. grahamtriggs
    grahamtriggs
    Nov 19, 2002
    779
    28
    +33
    IMHO, it's the best that you'll get for a 42" Plasma for around £1500.
  3. Todda
    Todda
    If you could possibly stretch to 2 or 3 hundred more you could could still pick up the Panasonic PW6. In my opinion, there is a big difference in picture quality between the two.
  4. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,122
    Fife
    +686
    I have quite a small living room (approx 12x10ft), so it doesn't have to be 42" as this may be too big.
  5. trebor21
    trebor21
    Oct 11, 2004
    35
    This is avaliable for £1469.67 from empire direct
    Samsung Ps42v4sx
    Due to be recieving one in the next couple of days ordered last week, I can give you an opinion on that once i get it!
    Spec is pretty good for it anyway
  6. sparkymark75
    sparkymark75
    Jan 6, 2003
    3,122
    Fife
    +686
    OK cheers, look forward to your initial impressions.
  7. Todda
    Todda
    That will be fine for a 42" screen. My living room only has a depth of 13ft and I had 96" screen in it.
    It all depends how far your plasma and seating position wil be off the wall.
  8. elliott-cardiff
    elliott-cardiff
    Aug 22, 2004
    53
