Best for 500quid?
Discussion in 'Blu-ray & DVD Players & Recorders' started by img, Aug 10, 2004.
  1. img
    Jan 22, 2004
    589
    +17
    I listen to CD`s and well as watch lot of movies is there anything good for max of 500 quids that will give good cd audio. Doesnt seem to be much in reviews that say about it
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HK DVD 30 if you can find one or try new DVD 31 DVD 25/30 was very good for CD replay!
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,572
    Edinburgh
    +1,268
    If you can stretch your budget a bit more you could get the Arcam DV78 for around £700 which is very good at CD replay. Another option would be to get a cheap DVD player like the Toshiba SD240 or the Pioneer 575 and purchase an entry level dedicated cd player like the Rotel RCD02 or the Arcam CD73.
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    Can I suggest the rather splendid Denon DVD-2900 which can be had for around £550 now (was £850)
  5. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Get a Pioneer 565 for DVD (£120)
    and a Rotel RC-03, NAD 542, or Arcam CD 73 for CD (around £350-£400)
    If you insist on one-box; Pioneer 757, Denon 2900 or (used) Arcam 78.
    Personally, I use a Pioneer 565 for DVD (paid £150) and run it into a Tag DAC20 (paid £285 used) for CD, with fabulous results.
    DT
  6. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    If you only want one unit, the Arcam DV88+ from Creative Audio at £499 (was £1K) is hard to beat. Supposed to be the best DVD for CD play under £1k. The DV78 is essentially the same performance wise, but is replacing the DV88+ as it is cheaper to make.
    See it here:
    http://www.creative-audio.co.uk/arcamdv88off.htm
  7. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    251
    If you can wait a little while, the new mid-level Denon looks very good, if not the Rotel 1050 isnt that bad either.
    Fish
  8. img
    Jan 22, 2004
    589
    +17
    i got a denon 2803 atm.
    Whens the new denons out?
  9. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    What about an excellent condition 2nd hand multi region Denon 3800 for £320.
    One for sale in the classified's section ;)
  10. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    251
    Towards the end of August.
    Fish
