Best for £60 ish - SOUNDSTYLE Z2ii SPEAKER STANDS?
BiffBoy
Member 398526
Hi there,
I cant really comment on the soundstyle stand as it is not one I have used, but I can recommend another that is great value for around that price:
The Atacama Nexus range, you can get the 5i (50cm tall) or the 6i (60cm tall) for your kind of price range, and either is available in Black, Silver, or Graphite finishes.
Big AV Atacama Speaker Stands
They are an excellent stand, and as well as being supplied with carpet spikes, you also get the isolation gel pads to mount your speaker on.
mrbenn
they cost nearly as much as your speakers!!!! IMHO i would build some and save the money for speaker upgrade.
if you make then you can get them at exactly the correct height
