Best Floorstanders for £400 - £500...
Discussion in 'Home Cinema Speakers' started by MrP 2001, Feb 25, 2003.
  1. MrP 2001
    MrP 2001
    Hi all,
    Been an avid fan of B&W speakers since I bought a pair of 602 S3's a year ago. However a friend of mine knocked one of my speakers off its stand and buggered the tweeter. He is going to give me £275 to replace them.
    Therefore I have an opportunity to upgrade!!
    Now I was thinking of saving up and getting a pair of 603 S3's but thats going to be £600 quid. Are they worth £600?? If not wants a good alternative as a floorstander for around £400 - 500. Or should I save up for the B&W's as I really like the sound of the 602's.
    Any advice or opinions would be greatly appreciated so I can have a listen to what you guys suggest - rather than listening to what the salesman suggests!!!
    Patrick
  2. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    You know you can ring up B&W and they may send you a replacement tweeter totally free of charge (don't tell your friend this, heh)? Their customer service is excellent. Quite easy to fit yourself too - just remove the bass driver, unscrew the front baffle and ease it off (taking care not to tug on the internal cabling). The tweeter assembly has no fixings whatsoever. It's a twist-fit and extremely easy to remove/install. If you don't fancy doing that I'll buy the speakers off you (serious). :)
    The 603s are great, yes (go and get a demo if you are interested), but I would urge you to get your 602s repaired and consider buying a decent sub. £275 would be enough to totally cover the cost of a secondhand REL Q100E or new Velodyne VX-10, and go along way towards the purchase of a Velodyne CHT-10 or one of the mid-range B&W subs.
    MuFu.
  3. MrP 2001
    MrP 2001
    Result!!!
    Cheers mate for that. I will get on to them tomorrow. And I will also inform my friend that Sevenoaks HiFi charge £50 for a new tweeter :D :D at which his must pay!!
    So in your opinion rather than me sell the B&W's, get a decent sub instead. I listen to music 80% of the time rather than surround - will a sub and floorstands combo be better than some floorstanders?? Also, what subs can you recommend that will be able to follow my Yamaha amp with volume (i.e. won't distort when ive got it cranked up) and will be best with music.
    Cheers again mate (its very rare that you get these things for 'free'!!!)
    Patrick
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    :thumbsdow
    I am glad I am NOT your mate
  5. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    It's not really my business to get into the morality of MrP 2001's situation so I tried to avoid the subject. That comment was just a joke.
    MuFu.
  6. MrP 2001
    MrP 2001
    Dont u worry!! I spoke to my mate and he is a tad relieved to say the least!!
    So anyone got any sub suggestions for say £200 - £300....
    Pat
  7. MrP 2001
    MrP 2001
    Turned out to be £31.50 for a new tweeter all in all (not free :()
    But I don't think thats bad for a B&W Tweeter... My mate best get his wallet out after all!
