Best file format for ripping DVDs
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Mar 21, 2006.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I'm looking at ripping my DVDs to my hard disk and was wondering which file format to use. I've used AnyDVD to create TS files, but these come out at over 4GB. What is the best file format for a lower file but still keeping the video quality?
    Oh, it has to work in MCE too !!
    Cheers,
    Richie.
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    dvddecrpyter?
  3. Rambles
    Rambles
    Jul 14, 2004
    10,311
    167
    UK
    +2,083
    Yes, DVD Decrypter in file mode works well with My Movies - DVD Shrink will get rid of extra's and/or compress the video if you prefer.
  4. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Well if you wanna keep it simple and the folder structure intact I would highly recommended DVD Shrink. Insert the DVD, let it finish scanning the disc, then click "Backup!" all done ;)
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Thanks guys.
    I've used DVD Shrink but it outputs TS files. Is 4GB about the right size for a DVD film ?
    Richie.
  6. Rambles
    Rambles
    Jul 14, 2004
    10,311
    167
    UK
    +2,083
    They are normally between 4gb and 8gb, if you used DVD shrink it may have compressed it to 4gb.
  7. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    If you want to save a bit of space you could try AutoGK to compress them to Xvid format - Guide here:-http://www.doom9.org/index.html?/autogk.htm
    Just noticed it has to work in MCE - not sure if MCE plays Xvid files, but i'm sure you can get add-ons that will allow it.
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Cheers Willsy, I'll give that a try.
