"Best" entry level DV camcorder?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by robinbowes, Jul 8, 2002.
  1. robinbowes
    robinbowes
    Jul 8, 2002
    10
    I guess this is one of the more frequently asked questions, but I'm looking to buy an entry-level camcorder for home use and would appreciate any advice.
    My key criteria are as follows:
    compact & easy to use
    can be connected to computer
    still images
    long battery life
    good quality picture
    My budget is up to about £600, preferably less!
    Any ideas or suggestions?
    Thanks,
    R.
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    robinbowes,
    Investigate JVC GR-DVX507.
  3. AAA
    AAA
    You can get soon to be discontinued Canon MV4MC, comes with DV Card for your PC for around £600. It is very small,lovely Cam!
    OR
    Get Panasonic NV-GS4B , USB,.....,£599,
    OR
    Panasonic NV-DS30, £399, no USB!,....., bigger,..
    Regards,
  4. robinbowes
    robinbowes
    Jul 8, 2002
    10
    Thanks for the suggestions.
    One further question: the Sony DCR-TRV240 seems to have everything I'm lokoing for and is reasonably cheap, however it is Digital8 format rather than MiniDV. Should I keep away from Digital8 or would this be an acceptable comprimise?
    Thanks,
    R.
  5. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    The picture quality difference between Digital8 and miniDV is substantial. The only reason to go with digital8 is to save money.
  6. robinbowes
    robinbowes
    Jul 8, 2002
    10
    Thanks, I thought as much.
    I think I've all but decided to push the boat out and get a Sony DCR-TRV25 - £680 from http://www.askdirect.co.uk (unless I can find one cheaper down Tottenham Court Road on Saturday!!)
    Cheers,
    R.
  7. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    +32
    Good choice, hot price too.
