best dvd's for quality?
rhino2k
hi all, i have heard many times that r1 american dvd's are usually higher quality, as are the games. is this really true, as a quick google reveals pro's and cons for ntsc and pal :confused:
having a MR dvd player it would be a shame not to take advantage of higher quality movies :D
i guess this is the part where you tell me some are better as pal, some ntsc :rolleyes:
Conn
Yep :) Depends a bit on what you are watching them on, a bit on the master used.
D
Dave Mack
If both are taken from the same master then the PAL should look a bit better with the extra lines of res. My R2 PAL LOTR EE and Gangs of N.Y. and SW ep. 1 are MUCH better PQ-wise than the NTSC R1's. and I live in NTSC land!
:) d
Trending threads
Trending threads
