Best DVD source?
Discussion in 'Projectors, Screens & Video Processors' started by Punce, Mar 4, 2002.
  1. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    right then, which one would be the best quality? would it be:
    1) DVD player with PS compnonent -> PJ
    2) DVD player -> Capture Card on PC -> DScaler -> Powerstrip -> PJ
    3) DVD-ROM drive -> Powerstrip -> PJ
    answers on a SAE and send to...:D
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    1 or 3. My money goes with 1 as I am now officially fed up with 3.
    Most (panel) projectors scale quite well therefore I think the real trick is to get a good PS signal into them. Projectors that can't take a PS input are a no no nowdays in my book.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Ah, a trick question me thinks. It would depend on the source and the various components. I personally use No 3 with the addition of Cineplayer 4 & Zoomplayer because Powerstrip stinks at playing DVDs. ;)
  4. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    After reading a fair bit on avsforum, I'm having a few doubts on using the component input of the AE-100E, Li On says it looks crap
    I'm thinking of using my WinTV capture card for Sky and PS2 etc, and I was just wondering how a DVD-ROM would compare to a stand alone player for judder etc.
    Jeff, another thing, what do you fo for sound? I'm got a Sony 930 AV amp, and I would like to use 5.1/DTS. I've got a SB Live with SPDIF out mini jack, would the sound be as goos as my Pioneer 525 DVD player?
  5. Timh
    Timh
    Sep 14, 2000
    5,262
    3
    3
    Altair-4
    +339
    you should try the componant imput, it's pretty good, I think Li on must be a bit fussy.
  6. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    It was in his own opinion, possibly he has better eyesight than your average eagle, but I'm sure there's some truth behind it.
    Tim, have you ever tried a HTPC set up properly with the AE100E?
  7. Timh
    Timh
    Sep 14, 2000
    5,262
    3
    3
    Altair-4
    +339
    Yes, I have tried the HTPC route briefly, with my Creative dxr3 card, it was a big jump in picture quality, but I coudn't get powerstrip working, so I coudn't try 856 x 480 (480wide), this resolution is supposed to rock.
    I will give it another go when I upgrade my PC.
  8. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    I seem to remember reading your posts now.
    Yeah, now that they've cracked the correct Powerstrip settings, it would be very interesting seeing the results, and soon as Panasonic send out the new stock, I'll be able to play about with it myself ...so to speak :rolleyes:
    I'm just a little concerned about decent sound!
  9. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Punce,
    Which live card do you have? An early one or one of the newer 5.1 cards?
    Jeff
  10. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Thought of trying PSI's PD 1000? It offers scaling inside the DVD transport and outputs as RGBHV (DVI soon) only. It is $1999 - $2500, and the company offers $10,000 reward to anyone who finds a better DVD Video option!
    Cheers Kane
    PS I would go for this if I didn't already have a Toshiba SD900E! It is meant to rock!!!!
  11. acave
    acave
    Feb 8, 2002
    845
    28
    London
    +32
    I was more than happy with the component input until I used my PC and now I'm not happy with component.
    Now I'm hooked on projectors.
  12. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    My Sound Blaster is the 1024 (CT4830) and it has got an SPDIF digital out ( a yellow mini jack socket)
  13. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The old Live cards have a non standard voltage on the spdfif port which could damage your receiver/amp, so you might want to upgrade to a newer card. To go from the mini jack connector which most sound cards have to Digital Coax all you need is a mono mini jack to RCA adapter which costs 52p from RS.
  14. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    Thanks, I better not try anything with this card then :rolleyes:
    If I go down this route, and start upgrading bits, do you reckon I should go for that M-Audio 24/96?
    In fact, could I ask you for 3 recommendations?
    1) Graphics card - I believe the Radeon 7200 is good ( if you can find one)
    2) DVD-ROM - Pioneer 106 seems to be a favourite, any good DVD/CD-R combi drives - ie quiet and multiregion inc. RCE?
    3) Sound card - the above mentioned?
  15. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    All good choices, you have been doing your homework.
