Best DVD setup disc?
Discussion in 'Movie Forum' started by sraper, Jan 21, 2002.
  1. sraper
    sraper
    Aug 7, 2001
    522
    Watford, UK
    +84
    I am finally going to get around to buying one the setup discs. However I am aware of three:
    Ultimate Dvd Platinum
    Video Essentials
    Avia
    Which of these is the best all round? Especially which ones can help setting up PAL. I believe Video Essentials is NTSC only :(
  2. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    Ultimate DVD platinum is quite good, I know a lot of magazines use it to test DVD players, I've got Ultimate DVD Gold, and that worked great setting my system up. Video essentials looks better than Ultimate DVD Platinum, but I dont know if its only NTSC or not, I'm waiting for mine to be delivered. Never heard of Avia. Hope that is of some help.
  3. graham.myers
    graham.myers
    VE is only NTSC. I ordered mine from Oz because it was cheap (£15 after C&E had handled it :-(
    Also note that despite being listed on the introduction narrative it does not have DTS or PCM setup options. There is a fly sheet inside the case telling you so - not much use AFTER you've bought it. Also they mention chapter stops (lifted straight from the LD version, lazy tourags)
  4. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Ultimate DVD Platinum is a pretty good 2 disc set (1 set up, 1 demos). The commentaries on the tests are informative.
    It's R1 and therefore NTSC only, however.
