best dvd recorder.?
Discussion in 'Blu-ray & DVD Players & Recorders' started by deltafx, Sep 18, 2005.
  1. deltafx
    deltafx
    Aug 21, 2003
    516
    +7
    that will let me record from sky+ harddrive. record from vhs tape. and record
    from digital cam. for around £300.00 or less
  2. deltafx
    deltafx
    Aug 21, 2003
    516
    +7
    ok then not the best anyone recommend a good recorder that will do all of the above
  3. mgiazzi
    mgiazzi
    Mar 6, 2005
    91
    11
    +6
    Hi there,
    I reckon on this player as it has dual layer capacity,i link for digi cams and writes to all formats except dvd ram.I have seen this for £159.00 on ebay and think this is a real bargain.
  4. yabadaba
    yabadaba
    Dec 30, 2002
    89
    London
    +3
    Yes, I was tempted by the Sony 210, but didn't go for it based on the problems reported with RGB pass-through. I went for the Panasonic DMR-ES20 instead...but that doesn't have a DV-Input. Still makes nice recordings from my camcorder via s-video and has freeview, though.
  5. bob*
    bob*
    Liteon 5005 B ?
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    Have a look at the 'Which DVD Recorder?' link in my signature!
  7. ComfortablyNumb
    ComfortablyNumb
    Apr 1, 2003
    89
    11
    Hi I bought the Sony HX710 from Pixmania for £306.00, OK not UK stock, European, comes with a full Sony Pan European warranty, has 160gb, DV in, Dual layer, and you can hook your old video recorder up to it, they only thing it doesnt do is SACD and DVDRAM.
    Its the 1st time I've bought from Pixmania and I'm still playing with the machine, as it only arrived 10 days ago, but like you I wanted all of the above and only had a £300 budget, this will probably retail for £499 when it hits the UK shops, so IMHO it was worth a punt for such a large saving.
  8. HelenS
    HelenS
    Does it just have a normal analogue tuner when it's a European model? I'm assuming it's not the Freeview one that the UK version has...
  9. ComfortablyNumb
    ComfortablyNumb
    Apr 1, 2003
    89
    11
    Hi Helen
    Yes just the analogue tuner, again this wasn't a problem for me as I have the Sky+.
    CN
