Best dvd recorder for Sky+ HD - £100-£200
Discussion in 'Blu-ray & DVD Players & Recorders' started by Claire G, Feb 8, 2009.
  1. Claire G
    Claire G
    Feb 8, 2009
    12
    Can anyone please advise me on a decent dvd recorder to use with Sky+ HD, budget is £100-£200?
    Also, not very tech minded, how would I set it up as Sky box plugged into HDMI 1 and PS3 plugged into HDMI 2?
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    sounds about right for the hdmi leads
    a sony 870 or 890 or 995 should suit you with the sky box tv out scart plugged into the line 1 input of the recorder
    or a pioneer or panasonic will also do the same job
    note that it will be in SD and not in HD ( you cannot record HD yet )
  3. Claire G
    Claire G
    Feb 8, 2009
    12
    Thanks very much. I'll take a look.
